99 outback transmission problem
R
RoadCycle
Hi folks,
My 99 subaru outback has a transmission problem. When you put it in
drive it doesn't engage right away. Sometimes takes 20-30 seconds of
stabbbing the accelerator. Dealer says it's got an internal
transmission problem and the trans will soon die. Anyone have any
experience with this?
Thanks!
RoadCycle said:
Hi folks,
Thanks!
Well it's all your fault for buying a car with a slushbox on it. Subi
makes some awesome manual transmissions and to purchase the slushbox
model instead is such a shame.
East-
RoadCycle said:
Hi folks,
Thanks!
I'd recommend trying a through transmission flush, though it is quite
possible the dealer is correct and those funds would be wasted - there
are plnty of folks whose transmissions were gummed up from improper
mainenance/whatever and a flush fixed it.. Not just a drain & refill, a
true flush. Call around for prices and see what you think. It's a gamble.
Yes:
I just got my 99 Outback out of the shop for the same problem. There is a
piston and a set of seals that wear out. The entire transmission is not
failing. The repair can cost up to $1,600 depending on what other things
they find. Price this at a few dealers. Some are more reputable than
others. My dealer actually came in at $100.00 under the quote. By the way
my Outback has 113,000 miles on it and this was the first major problem with
the car.
skidude
