'95 Outback - Washer nozzle
H
Hallraker
The passenger side washer nozzle on my '95 Outback is clogged. I've been
dealing with it for a while but need to get this taken care of before the
salt hits the roads in a couple months. I tried blasting it out with
compressed air, but apparently whatever is in there is stuck fast. Dad's
trying to soak it in some solvents that will probably dissolve the whole
thing (lol). Failing that, anyone have any other ideas/methods to get it
working?
If all else fails, I'm going to head up to the dealer or maybe check a
junkyard, but I've yet to find a local yard with a wrecked Legacy.
-Matt
Best if u can disconnect hose and remove nozzle then poke it from the
outside (thru jet where the water comes out) with a dressmakers pin or
copper wire about same dia. Blow through from same side & check it's now
free. Check it works on the line then put back together properly. Worked
on a 99 OB anyway! Cheers
Donnyboy
