2003 OBW, 2.5 l, auto, Dyno readings
A
AS
Using the Auterra software (www.auterraweb.com), I did some testing to
measure the chassis power and torque for the wife's 2003 OBW, 2.5 l, auto:
The highest readings i got:
Power: 142 hp @ 4300 rpm
Torque: 145 ft-lb @ 5100 rpm
From the Subaru specs:
Power: 165 @ 5600
Torque: 166 @ 3600
When using the A/C, the chassis power and torque go down to 138 hp and
140 ft-lb.
The tests were performed in second gear, from 2000 to max. rpm, on flat
paved road, tire air pressure to specs, fluids to specified level except
for fuel which was about 4 gallons in the tank, no loads on the car, air
temperature 80F, wheel alignment verified to nominal specs.
I do not want to imagine where the missing power and torque are. ;)
Power: 165 @ 5600
Torque: 166 @ 3600
When using the A/C, the chassis power and torque go down to 138 hp and 140
ft-lb.
Missing? It was never there....
these imaginary specs of 250-300BHP are just that..a dream....
Not ONE of them has a dyno run sheet to PROVE it....
hmm, that could be right depending on how your results are supposed to
be interpreted since Subaru power/torque specs are reported at the
flywheel not the road, and you lose about 15% through the drivetrain.
Power: 165 @ 5600
Torque: 166 @ 3600
140 ft-lb.
I would be a little suspect of your software's readings. While I don't
have any data in front of me, from memory most manufacturers quoted
h/power is at the flywheel and the only way of getting an accurate
measurement would be using a 'rolling road' dynomometer.
Secondly most torque is usually developed at a lower RPM than max HP.
Power: 165 @ 5600
Torque: 166 @ 3600
140 ft-lb.
You might enjoy searching/posting your question at the Proven power
forum at www.nasioc.com . many folks there have put their soobs on 4
wheel drive dynos.
Carl, great suggestion, thank you.
Thanks to all others for the comments and suggestions.
Alex
Power: 165 @ 5600
Torque: 166 @ 3600
140 ft-lb.
I'm guessing the tool measures power at the wheels, since that would
make physical sense... in that case, your numbers look really damn
good. Most people only manage to get low 130's at the wheels, even with
a manual transmission.
Power: 165 @ 5600
Torque: 166 @ 3600
140 ft-lb.
You are comparing apples and oranges.
You are measuring "chassis" horsepower or "on the ground"; Subaru's
measuring it at the crankshaft. The difference is used up in mechanical
losses in the transmission, differentials, CV joints, wheel bearings,
rolling resistance of the tires etc and etc. Don't forget the alternator
and possibly the water pump.
As you already noticed, the AC takes 4 horses to run.
Also be aware that *any* horsepower measuring device is only as good as
its calibration. Most folks who deal with either engine dynamometers,
chassis dynos and accelerator gauge/software dynos only use them for
estimates. Their value is showing how much (and where) the horsepower
and torque changes with tuning and modification.
lenk
