A
Al Blake
We have a 1983 1800 4WD wagon. It has been very reliable over the last 5
years and only required regular maintenance.
Over the last month it has taken to dying without warning. Leave it for 5
minutes and try to restart and it is fine for a another few days when we
have the same problem recurr.
As you would imagine this is pretty frustrating.
Initially I suspected fuel - but I have tested the fuel pump and it is
perfect in terms of pressure and flow rate.
Last night I was out in the car when it died (half way across the highway!)
and I had some tools in the back. So whilst I was waiting to get towed home
I tested the ignition and found NO SPARK. I had a good battery and the
engine was turning over, I also had 12v at the coil but when I put an
earthed plug on the COIL lead there was no spark (ie I wasnt just checking
whether the spark was getting out of the distributor cap).
So to my way of thinking this eliminates the fuel system (obviously!) and
the distributor cap and rotor?
Here's the thing. I put the car in the garage and shut the door....when I
came to start it today everything was fine again..it started first time .and
when I checked the spark on the coil lead it was HUGE. So my questions are:
a) Any suggestions as to what the problem is?
- ignition coil?
- electronics within distributor?
b) Has anyone ever heard of an ignition coil intermittantly failing and then
recovering - I mean could it fail when hot then recover when cold?
Any tips would be appreciated.
Al Blake, Canberra, Australia
- ignition coil?
