A
Al Blake
We have a 1983 1800 wagon which has done about 250,000 kms.
Car starts reliably and drives ok *but* it is using a lot of water.
Filled it up last week and it has used 2-3 litres in 5 days!
I have spent hours searching for leaks (including using flouro dye) and cant
find any....so I am wondering whether the problem is in the cylinder head(s)
but when I do a compression test I get:
150,155,145,150 psi for the 4 cylinders.
Question: Is it possible to have a cylinder head leak that would use lots of
water *without* having a noticable drop in compression?
(when I have had head gaskets go in the past the car wont start and/or the
compression drop is big).
Anyone seen this before? Needless to say I have checked the water pump
(replaced 2 years ago) and it looks fine too.
If its the cylinder head how can I tell which one if the compression is
good? Or do I just have to replace both anyway
Suggestions welcome.
Al Blake, Australia
Al Blake, Australia
