I bought my STi last year in July, it had 129,xxx miles at the time of purchase and ran fine. After a couple of months it started to have a light grey smoke come from the exhaust on start ups or when getting to a higher speed on the on-ramp. I decided to do a combustion test to see if I had a head-gasket problem but it came back good. I then tested compression and had about 120PSI on each cylinder. I thought maybe it was just something that would go away (I know that's dumb to assume but I was busy at the time and just needed a car) but after a week or two I ended up having a miss-fire in cylinder 4, I instantly replaced all 4 spark plugs and coil packs which ended up with the misfire code not showing up anymore. A couple of weeks after that my check engine light showed up again with a code for the CAT. I set-up a appointment with a mechanic to have it looked at and a week before I was scheduled to go in I was driving home and my car died while coming to a stop. It was so quiet that I didn't even realize it until I put it in gear, I tried starting it again but nothing happened except for it trying to turn but no start. I tried to diagnose it by having my battery and alternator tested which the battery came back good but the alternator came back as failing so I bought a new one but it still didn't wanna start. I tried checking the codes again and kept getting random codes related to my ECU. I took it to a mechanic and he refused to do a leak-down test or anything else and said just by hearing what I told him that it was the engine and it would need fully replaced. Do you guys agree with his diagnosis or is there something else I should check out before going the route he offered?
