Wind noise in '91 Liberty
Danny
Hi there,
Does anyone know a fix to reduce/stop the wind noise coming through the
front window seals in a Liberty?
There seems to be a tiny gap just where the window glass meets the
mirror surround (I guess it's the downside to frameless windows). The
noise is annoying at highway speeds.
Any suggestions appreciated.
Dan
'91 Liberty
There's always 'some' noise around that front fillet but tihis may help.
Take off the door trim panel on the worst side first. Looking at the door
metal at the bottom of the window you should find two little metal doovies
with a bolt through them . Back off the bolt and they slide in and out,
tensioning the glass. Sliding towards the outside of the car puts pressure
against the bottom of the window and tilts the whole panel inwards,
forceing it in against the seal once the door closes. Bit of trial and
error to get it right. MAKE SURE you reconnect any window/ door/ mirror
connectors you removed before you finish re-installing the panel. Cheers
miachapman
