AJB said:
the big air noise comes dead center of front windshield at the bottom
where
it meets the dash. it's a rushing sound, and yes, it varies with the
wind, quite noticeable.
i do get some around the side mirrors and will try folding them back plus
the other fixes suggestedhere.
dealer now wants to remove windshield, replace seals, etc. and i'm a bit
resistant because it is a new car. i didnt buy a new car to start having
parts repaired and replaced.
age of your car?
Your issue is not the same as mine. Mine is a whistling--as in an actual
whistling, not just rushing air--as in an actual note of sound, and not
just the sound of fast air through treetops. It happens only at about
160kph (more or less depending on cross-wind) and immediately ceases if I
tuck the mirrors in. It differs depending on who is sitting in the car, and
whether there are passengers and how heavy they are.
Others report similar problems, but it's clear the noise is coming *only*
from the joint in the side rearview mirrors, and the fix is to either learn
to tuck the mirrors in, or prevent the flow of air over and across the
mirror joints.
I do not consider this a flaw by any stretch of the imagination.
Every WRX that I know of has this same issue.
Every STi that I know of has this same issue.
My 2002 WRX had it, and now my 2004 STi has it. I am not concerned, because
the fix is so simple.
