Tumbler Generator
I
IDG
My wife has an 2005 Outback 2.5XT and a few days ago her check engine light came on and the car didn't want to accelerate. She turned it off, restarted and it has been fine since. We went in to the dealer who said the Tumbler Generator needed to be replaced. Can anyone explain what this part is?
IDG
--------------= Posted using GrabIt =----------------
------= Binary Usenet downloading made easy =---------
-= Get GrabIt for free from http://www.shemes.com/ =-
I am from the UK but have heard of many US auto terms and suspect the garage
is B.S.ing you. Have never heard of a "tumbler generator".
Marcus said:
I think it's located between the venturi cognito
and the timing belt ratchet.
You mean ported tumbler generator valves
Ron
And it really doesn't matter if
I'm wrong I'm right
Where I belong I'm right
Where I belong.
Lennon & McCartney
The tumble generator is a valve like thing in the intake manifold.
The generator breaks up and mixes the incoming air charge to provide a
more uniform air mixture at low engine revolutions. I'm not sure if
it's ever meant to or needs to be replaced as I thought it was just a
mechanical device. ed
news.ops.worldnet.att.net>,
It has electronic positioning motors and
positioning sensors.
This is fascinating! Obviously it is an important part if Subaru went to all
that trouble, so it could actually be the cause of the original problem. Any
idea why it is needed in this engine while most others don't need it?
Mike
I consider it a real plus because it not only helps emissions and
smother warm up but, it also improves low engine speed torque.You do
find this type of thinking on more expensive vehicles.
What is it?
Thanks!
Similar Threads
Velocity Tumbler Valve? 1
subaru generator 9
