service needs after 100k miles
T
tenplay
My '96 Legacy L recently went over the 100k mark. Besides the regular oil
and lube, what else needs to be done at certain intervals to keep it running
well? Do you just keep following the same recommended servicing schedule as
for the first 100k miles or does it need more servicing because the car is
older?
First and must, timing belt. Depends how long you want to keep it.
Check brake, flush rad, flush tranny, replace spark plugs, battery is
getting old as well. Owner's manual is good starting point.
Tony
older?
Have you done the timing belt?
If not, timing belt, crank and cam seals, water pump,
and timing belt tensioner. Since it's apart, it's
a good time to change the plugs, fan belts and coolant.
skidude
