Remove what fuse to immobilize 05 OBW?
G
Guest
When leaving my 05 OBW parked for a while away, I'd like to immobilize
it so that orinary hot wiring etc. would not work.
In the old days removing the distributor rotor arm would do the trick
but now I'm thinking of removing a major fuse. But I don't want to
lose any settings etc. by doing this.
Comments?
Theres probably a fuel pump fuse in the engine room. Removing that
should only affect the fuel pump
It's a Subaru.
Press the button on your keyring, and have faith.
It's impossible to "hotwire" one in the traditional way.
To get the thing running and moving, there's quite a few lockouts, and the
ECU is tied in with the alarm IIRC.... Don't worry about it, it ain't going
anywhere.
-mark
Mark said:
It's a Subaru.
going
anywhere.
-mark
As an autostart specialist I can assure you that it can be hotwired in a
matter of minutes with the factory "alarm" turned on.
Chris Dalton
