re 2000 legacy question
U
uandeye
Looking at a 2000 Legacy L wagon with 90000 miles.
Anything I should look out for?
Phil J
phil
make sure it has a new timing belt and, if it does, why? if not then replace it CAREFULLY. check for cam seal leaks and, if it has a new set of tires, make sure they are matched and the right size and that they match as they are a bit different.
of course, check for leaks. maybe other stuff but that's my take after two subis.
oh yes. make sure that you can locate a reputable dealer close by. there are some nasty ones out there and there is some times a problem getting a mechanic to fix subarus. at least, i have that problem here in port charlotte, fl. the car should last for several hundred thousand miles if it's okay to start with.
--------------= Posted using GrabIt =----------------
------= Binary Usenet downloading made easy =---------
-= Get GrabIt for free from http://www.shemes.com/ =-
Very close to the timing belt and recommended water pump replacement
interval. The cost for this is about $500 at the dealer level so
factor this into the cost equation. Some vehicles also had rear wheel
bearing problems which can be another $300 IF they are making any
noise.
kraabet
