Question about AWD
G
GTT
I've been lurking in this ng for a few weeks and now that I've bought
my Subaru, I begin to remember comments that I wonder if I need to
understand better.
For example, some time back, one of the knowledgeable posters
mentioned a "situation" in which a Subie owner might want to
cripple AWD and use FWD only. I believe the suggestion was to
pull a fuse, or press a switch, or ???
But I forget what!
Old too soon, schmardt too late!
Could the original source, perhaps, refresh me on that?
In What situtation would I want to use FWD only and
HOW would I cause that to happen on my Subie?
Any help?
While I am certainly not one of those "knowledgible" people you are
referring to, my owners manual says that if you have AT, stick a spare fuse
into the socket to dis-engage the drive to the rear wheels, so that the car
can be towed by lifting only the front.
There is no way to do this with MT.
Never heard of the ability to do it. But why would you want to? It won't aid
you in any way apart from causing you to not have the best traction setup
that the car can give you.
I would think that being through the drive shafts, you would probably need
to disconnect the shaft not pull a fuse. Look at you manual and brochures
and you will see it is a solid drive line.
This is necessary becuase the spare tire is smaller. If the spare is put on
the rear, you need to disengage the RWD. I believe I saw this in the latest
issue of Drive, or it may have been in the manual.
This does NOT make the car safe for towing. I repeat it
does NOT make it safe for towing.
It allows the use of the temp spare tire on the rear of an
automatic equipped car. Due to the difference in
transmissions, it's not required for a manual
understand better.
But I forget what!
Any help?
Not sure who the original poster is, but Subaru recommends using the
FWD mode when using the (small) spare tire. It's in my owner's manual.
You do it by putting one of the spare fuses in the FWD slot in the
fuse box. No fuse = AWD, fuse = FWD.
Hope this helps.
Nicolas
Cam is right. Additionally, you need to do this if the 'donut spare' OR
ANY DIFFERENT SIZED TIRE is used FRONT OR BACK. THis applies to AT
vehicles only. There is a spot in the underhood fuse box (older models
maybe somewhere else? anyone?) which needs a 15 (maybe newer models 20?)
anp fuse put in it to enable the duty 'c' solenoid permanently. Thsi
keeps the car in FWD mode so the center diff 'clutch pack' in the tail
of the AT doesn't burn up from thinking a wheel is slipping all the
time. This relates to why these cars should be 'flat bedded' when
'towed' AND why the tires should have proper pressure and be the same
style and circumference(within very close tolerances some say 1/4"!). Do
a search at www.usmb.net forums for more info.
1 Lucky Texan
Yessir, that was the suggestion I referred to. And you must be more
knowledgeable than I am! Thanks. Do you happen to know what a
"spare fuse" refers to? I'd suspect a spare fuse would be "good"
rather than blown, and sticking a good fuse into "the socket" would
accomplish what? (if I knew which socket "the socket" was, even.)
So you see, you are still a few miles ahead of me on this. Thanks for
the note.
Well, one reason was mentioned by a previous post; being able to tow the car
with the rear wheels disconnected.
Another might be driving on ice or snow when one has put chains only on
the front wheels.
May be others, I can't think of any right now.
"Cam Penner"
brochures
I suspect you are correct. My manual is very specific, tow the car on a
flatbed only!
But Foresters come with a full size spare, so that may be why that is not
included in my owner's manual... no need to compensate for the little donut
spare!
Thanks, Carl.
I guess I should have started with the fact that I've got a Forester and the
spares on those are full-sized. Probably the reason this is NOT in my
manual (at least after my extensive reading of that book)... I see that
another post has identified the fuse slot by name. Now I may be able to
find it.
I wonder, what the difference in front to rear size makes when placing
chains on the front wheels only? Seems like that would make more than the
specified 1/4" inch difference in circumference? Why does that not concern
the drive system? Hmmm. That was my initial concern, anyway.
Nicolas Dore said:
"GTT" <(e-mail address removed)> wrote in message
Hope this helps.
Nicolas
The original poster was me. And I appreciate your comment. It puts me
right into the matter.
Thanks!
I admit to being ignorant of the fact Foresters had a full size spare -
kinda cool actually. But I definitely wanted you and other readers to
know you really should not tow a Scoob AWD AT with ANY wheels on the
ground(especially just 2). The owners manual for my OBW claims that you
can place the vehicle in neutral and tow about 31 miles at a speed of
less than 20mph. That hardly seems useful so just wait for the flatbed.
Try to have your spare included in the tire rotations.
I suppose that since the manual says to keep your speed under 19mph with
the chains (coupled with the fact you would presumably be on ice or
other poor traction surface) the engineers figure there would be less
chance for 'torque bind' to build up or otherwise place damaging amounts
of stress on the center diff. Just a guess on my part. With such reduced
traction in the rear compared to chains in the front, the TCM will just
shift most of the torque to the front anyway I'd guess. If I had to do a
lot of tire chain driving I'd probably put the fuse in anyway.
See if there is a discussion in your manual listed under 'temporary
spare'. That's where it is in my manual. As you say, it just may not
apply to you.
1 Lucky Texan
Thanks, Carl.
find it.
Just in case anyone is reading, or searching this thread on
Google later.
Putting the fuse in to "disable" AWD does NOT - and I
repeat *NOT* make the car safe for towing with two wheels
on the ground.
NEVER EVER EVER do this.
(clear enough?)
on the ground.
Oops! Sorry, I think it was me that recently posted that.
Hope this helps.
Nicolas
i read this in the manual for my legacy too. but i have a manual
transmission. what do i do if i have to use the stupid little spare?
i asked the dealer and they said just to use the spare. but if i
can't open up the center differential somehow i'm afraid i might burn
something up running a little spare on the highway. does anyone know
how manual transmission drivers are supposed to handle the small
spare? or should we just wait for the flatbed to come?
thanks!
mike
thanks!
mike
Mike, wouldn't you think if they just wanted you to wait for the flatbed,
they'd never have put the donut spare in the car? The manual must say
something about it. Ask your service folks where you bought it.
In my "tour of your new car", we were given the fuse talk,
and then told that it only applied to automatics. Manuals,
due to the different type of differential, didn't need the
same treatment.
Mike Deskevich wrote :
I was told, though I haven't checked, that the spare is
the same diameter as a regular wheel, it's only smaller
width-wise. So it shouldn't cause any problems.
