Outback Trunk Latch
K
kb
i'm having an issue with my trunk latch on my outback. i took off the
door panel and used the safety switch to get it to unhook, lubed it up
with some WD-40 but it wont seem to work.
if i close the door and lock it, it will stay in locked position until
i use the safety again to open it. if it is unlocked the door will shut
but the latch that hooks into that little ring on the bottom won't
connect.
any suggestions are welcome, especially if it will save me the
time/energy/money of having to take it to someone.
connect.
If you think it needs lubrication, avoid WD-40. It is a better solvent
and 'water displacer' than lubricant. A good car parts store will have
the proper lubricant for a latch and, if you visit when they are not
busy, perhaps the counterman can take a quick look and offer additional
advice.
Carl 1 Lucky Texan said:
If you think it needs lubrication, avoid WD-40. It is a better solvent and
'water displacer' than lubricant. A good car parts store will have the
proper lubricant for a latch and, if you visit when they are not busy,
perhaps the counterman can take a quick look and offer additional advice.
To elaborate, WD-40 can be washed out with brake cleaner when it is fresh.
After a few years nothing will wash out the gum that remains.
Mike (the voice of sad experience)
MSDS
