Multiple codes
i have an 03 baja that has p0122 p0512 p1518 p0852 p0851 p0138 p0137 p0502 p0503 they all came on at the same time has anyone else had this happen
If only someone made a search engine you could use...
These specific diagnostic trouble codes frequently appear together in a cluster on Subaru vehicles (commonly in 2002–2007 WRX, Legacy, and Outback models). This combination strongly points to a main wiring harness ground fault, a shorted sensor, or damage from aftermarket modifications rather than simultaneous failures. [1, 2, 3]
The combination of your specific codes reveals several related issues:
  • P0122: Throttle/Pedal Position Sensor Circuit Low Input.
  • P0137 & P0138: Downstream (Rear) Oxygen Sensor Circuit Low Voltage / High Voltage.
  • P0502 & P0503: Vehicle Speed Sensor (VSS) Circuit Low Input / Intermittent/Erratic.
  • P0512 & P1518: Starter Request Circuit / Starter Switch Circuit.
  • P0851 & P0852: Neutral Switch / Park-Neutral Position Input Circuit Low / High.
  • P0502/P0503: Vehicle Speed Sensor. [1, 2, 3, 4, 5]
Common Root Causes
  • Bad Grounds: Many of these circuits share a common sensor ground. If the ground wire has corrosion, a loose connection, or was compromised (especially after an aftermarket alarm, remote start, or audio system install), it throws all of these sensors out of range at the same time. [1]
  • Shorted O2 Sensor: A shorted rear oxygen sensor can pull down the 5-volt reference voltage shared by other sensors (like the Throttle Position Sensor). [1, 2]
  • Starter/Inhibitor Switch: A faulty or disconnected starter relay wire or Park/Neutral safety switch will trigger the starter circuit and range codes. [1]
Diagnostic Steps
  1. Check for Aftermarket Wiring: If your vehicle has an aftermarket remote starter, stereo, or alarm system, verify that none of the connections are interfering with the starter switch or neutral safety wires. [1]
  2. Clean and Inspect Grounds: Check the main engine grounds and the grounds under the dashboard. Corroded or loose grounds are the #1 cause of this specific code cluster. [1]
  3. Check the Battery and Connectors: A failing battery or a dirty, loose connection at the Engine Control Unit (ECU) can result in low voltage spikes that trigger these multiple circuit faults. [1, 2]
  4. Inspect the O2 Sensor: Unplug the downstream O2 sensor. If the other codes (like P0122) disappear, the O2 sensor has internally shorted and needs replacement. [1, 2, 3, 4]
For tips on how to check your vehicle's wiring harness and ECU connectors for shorts and ground issues:
Related video thumbnail
2:08
How I Diagnosed This P0122 Check Engine Light ...
Online Mechanic Tips
YouTube · May 13, 2026
Stho151
