- Joined
- Aug 29, 2025
- Messages
- 1
- Reaction score
- 0
Hello I have a 1998 legacy outback 2.5. Recently my girlfriend went to start the car for work and it started up idled higher than normal than idled down and started shaking the car pretty bad. Check engine light came on. I’ve been chasing it for a few days now and I am at a loss. Current codes are
P0505, P0443, P0403, P1102,P0141, and P0135. P0505 was the first code to show up the test have come later. So far I have gone to the junk yard and swapped out multiple 3-4 of the same sensor off different cars of the same year and engine. EGR solenoid, exhaust recirculation solenoid, map and the biometric solenoid below it. I removed and cleaned the IAC valve. I ordered a used IAC. I have inspected the grounds I can find. Battery to body, battery to engine near starter, ground located on top of intake, and body grounds on front strut towers. Cleaned and sanded all of those areas including terminals. I located a ECU/PCM from another 98 2.5 matching my emissions being the 1Z same part number. Today after replacing sensors I got the car to run really well I drove it to my
Local parts store to clear the codes drove it 10 miles all good. Got home shut it off turned it back on. Boom back to square one.. I tried to explain everything the best I could but it’s been 3 days in the garage after work. Hopefully through a series of questions from some more skilled people we can get this resolved. I’ve also checked voltage at those sensors as well. Only once tho.
