Legacy Gearbox
R
Rob
Hi all,
I have a 97 MY Legacy 2.0 GTB Ltd Auto Estate.
It has 135,000 Miles and a full service history.
Serviced every 7,500 miles from new.
When I drive from cold the car starts off ok but on slowing down it judders
badly and makes a clunking noise, then stalls. On restarting if you try to
select D the car stalls, however, let it warm up for 10/15 mins it drives
fine.
Dealer has told me gearbox is U/S and a matter of time before catastrophic
failure.
Any second opinions ?
Regards
Rob
Hi all,
fine.
failure.
Regards
Rob
It sounds like the lockup torque converter is not unlocking when it is
supposed to. This is the equivalent of not releasing the clutch on a
manual trans when slowing down in gear, the engine will shudder and
stall.
The problem could be the converter itself, or just a bad control
solenoid. Is the AT warning light on? Even if it isn't, the TCU (trans
control unit) should be checked for stored trouble codes that may help
pinpoint the problem.
Of course I'm just guessing here but that's where I'd look.
mcselee
