keyless entry broken; cannot start car
jfp
I have a 98 Impreza Outback with keyless entry control unit
H7110AS011. This has, for a while, been acting flaky. I guess it
finally just died because today i could not start the car -- the only
electrical things that worked were the: emergency flashers; horn;
buzzer for key in ignition with door open; door locks. There was NO
response from car to either of two remotes. I locked and unlocked
doors, both manually from inside and via key from outside. I opened
and closed every door etc. Still, all electrical systems are dead.
On advice of mechanic, i located and removed the control unit. Still
dead. I then removed both 20A fuses from wiring harness going to
control unit. Still dead. So ... now what? Do i have to short some
of the wires in the harness together in order to get this to work? I
do not really care if the keyless system works -- i'll happily thorow
it away -- i never use it anyway -- but i sure want the car to work !
The "keyless" entry has nothing to do with the engine not starting. Do you
have another safety that prohibits engine starting?
Probably your alarm system disables your engine.
Same thing Im thinking here. Disconnect the negative battery terminal for a
1/2 hour and see if that resets everything.
Rob
Some Imprezas/Foresters have a small black alarm reset button mounted
at the bottom of the dash under the steering wheel. I think you need a
pen or something to hit the recessed reset button.
