High Idle with Check Engine Light
F
fly1747
1996 Outback Wagon with 2.2L engine. Car has recently suffered from
an occasional high idle, above 1000 rpm and higher when the A/C
compressor kicks on. Today it was idling normally and then started
idling high and the check engine light came on.
Any ideas before I go and have the code read?
Also, the gas cap was not fully tightened when I checked it this
morning.
Matt
Try starting it cold. Is the warm up idle the same speed as the abnormal
idle?
I might suspect a bad thermometer (car thinks it's cold when it is warm
causing the "warm up" sequence to continue).
Mack88
