daviddare73
Hello there.
I am having a problem with my left front brake making noise from time
to time, I took it to the Subaru guy here in Sacramento. He said they
were fine? It seems to make a scraping sound after the ebrake is
released and sometimes when I really press hard, it just sounds like I
need new pads or metal to metal. I wonder if these cars have piston
problems? Or if I should not worry about it.? The car is great
otherwise, go Subaru go. it has 164,000 miles on it. I think it's time
to overhaul the engine, seals atleast, it uses/leaks oil at about a
quart every 2 weeks or so. ECS light comes on, the mechanic said it was
a vacuum leak in the environmental controls, I'll fix this spring. Also
he said there was a trouble code from the Distributor system. He said
it could be a loose wire, nothing big he says. Should I believe him.?
Let me know if I should be more worried. Thanks-daviddare73
