For Tuning Purpose……Crank timing sprocket tooth count.
I am tuning a 2010 legacy GT 2.5 turbo. The tuner needs to know the number of teeth on the timing sprocket which triggers the crank position sensor.
anyone know or help?
I took the alternator off and ten removed the crank position sensor. That allowed me to look down at the teeth on the timing sprocket. I marked a tooth with red marker and then rotated the engine slowly while counting and observing the configuration of the sprocket.
Maybe this will help someone.
