differential ?
Marc Vooijs
I have an 4WD 1994 Subaru Legacy that is giving me a headache...
I have had a zooming sound at the right front tire. I have had the
right front axle replaced.
The subaru dealer said it was the 4WD that was broken and I disengaged
it by removing the fuse. The sound remained. They also said it could
be the transmission or a front wheel bearing. The sound remains when I
drive it in neutral.
thanks for any advice, marc
I've toasted a rear-differential on a 2003 Legacy. The noise sounded like
whirring (almost like a muffled cell phone) when I would let off the gas
while in gear as the engine acted as a break. Does not sound like what you
describe.
N
Sounds like a wheel bearing. I had one go and it sounds like what you are
describing.
If it is, whether it is in gear or not will make no difference. However,
you will hear the pitch of the sound increase and decrease with your speed.
It may also disappear at certain speeds. It might also reduce going around
turns, but usually only in one direction unless both front bearings are
shot; ie. it would reduce going around left-hand turns but not around right
or vice versa.
Hope it helps.
skidude
