Battery drain when everything off
V
VWWall
I have a 1995 Suburu SVX which shows a current of ~1 A with the engine
switched off and nothing else on. I tested this by putting an ammeter
right at the battery in series with the ground lead. I realize the
computer and even the radio require a small amount of standby power, but
this seems excessive.
I have tried removing all fuses, one at a time, with no change in the
current. I've looked at all the usual suspects like glove box and trunk
light. This occurred after the replacement of a knock sensor, which was
causing the "Check Engine" light to stay on, but may not be related. A
previous similar fault was caused by a bad electric door lock circuit,
but disconnecting that does not help. It passed the California smog
test OK, but the current is enough to drain the battery in a day or so.
This is my fourth Subaru, and I've had manuals for all but this one.
I'm not sure a wiring diagram would help, but I don't have even that!
Any ideas?
Virg Wall
switched off
Completely disconnect your alternator and see if the drain is still there.
SD
It could also be the security system which I believe is behind the glove box
in the SVX
in the SVX
Start pulling fuse to narrow it down. I hope it is not caused by a
shorted wire(real hard to find).
1 amp isn't a whole lot. Got a clock? Security system? Remote start
capability? All of those stay "on" to keep time, be ready to receive
commands, etc.
Also check the brake light switch. I have had those go bad (get electrically
leakage) on a few cars over the years. Dirt can do it.
MSDS
