Auto Transmission fluid change
John A. Mason
Hi All,
I have a 2002 Outback H-6 VDC Sedan with 120,000 miles. I have 'changed' the
automatic transmission fluid once by letting the fluid drain out of the
drain plug then refilling until full. I have never done a complete
flush/change-out (torque converter, etc). What are the thoughts about this
method?
John A. Mason
Comer, GA
John said:
Hi All,
the automatic transmission fluid once by letting the fluid drain out of
the drain plug then refilling until full. I have never done a complete
this method?
John A. Mason
Comer, GA
I had Clary's transmission shop (an independent in Seattle I've done
business with for many years, they know Subarus as well) do a flush on
my '00 OB at 99K miles as I bought it with 95K and had no service
history, just to ease my mind.
About 8K later, it developed the known 4EAT quirk of hesitation doing
into a forward gear when first started cold (goes away on warmup).
It's something to do with an aged O-ring that doesn't seal as well when
the gunk gets flushed out around it from the power flush. It's not a
disabling problem, just an irritation.
Rather than doing a teardown on the tranny, they suggested adding a can
of Seafoam transmission additive every 6-8 months.it swells the seals.
That works, I just dump in a can when it starts acting up. I can live
with this...
There may be other tranny additives that would work, but I'm not going
to waste time finding out. Seafoam brand stuff isn't stocked by Shucks
or Autozone. I get mine at NAPA, you may have to find a "more
professional type" autoparts store if you don't have a NAPA store nearby.
I'd still go with the flush, just be aware that it may cause problems.
There have been some instances where a flush uncovers a serious problem
that was going to occur anyway, the flush just accelerated it.
Hi All,
method?
John A. Mason
Comer, GA
Do it again. You're doing just fine.
In my experience, 'flushing' just flushes your wallet of cash. When I was
working for a dealer (used cars) we had two trannies flushed. The first
one waited until we sold it, and then failed about a week later. The
second one had to be flat-bedded about 1 mile from the place that flushed
it.
If the fliud is still, um, at least 'reddish', doesn't have black in it,
and isn't brown, drain and refill again. If it's brown, drain it, fill it,
drive about 3,000 miles and do it again. If it's black, put a Crepe on it,
it's dead... (I had a tranny run 12,000 miles like that..DON'T TOUCH IT!!!).
60,000 miles is about right for a drain and fill. You should be in good
shape.
If you're particularly anal about it, you could disconnect the high
pressure side hose that goes from the tranny to the cooler in the
radiator, with the wheels off the ground start the car, let it warm until
the idle comes down, put it in drive and put the hose in at least a one
gallon container. Five gallons is better. Keep adding tranny fluid to the
inlet as fast as it is running out of the hose. When the stuff running out
of the hose looks new, stop everything, reattach the hose, check the fluid
and add more if necessary. I think you can do this in neutral, too, but we
always did it with the drive wheels off the ground and turning.
with this...
This seems to be the recommended 'fix' for anything that goes a little off
on a Soob trans..."Get a can of Sea Foam..."
It seems to work. I'm not a big fan of snake oil, although I use Slick 50,
but it gets rid of hesitation and judders in Soob trannies...
Hmmm....I get mine at AutoZone, although every time I get one it has gone
up a couple bucks...
On this soob wouldn't that mean all four wheels?
What do you recommend for the filter, leave it if doing the simple
drain/refill and only change on the full fluid change?
My 00 OBW is due for one or the other. At 135K I'm apprehensive about doing
a full flush but a simple drain/refill, even a couple of times might be
worth it. But the filter...Hmmmm.....
BTW, AutoZones in MA have Seafoam on the shelf
That's where I am. That's where I get it.
Are you in Eastern or Lefter...I mean, Western MA?
If you look through posts over the weekend, you'll see I wasn't able to
get my filter out. On my '89 it is a screen, like most of the Jap cars I
have owned. I always buy one just in case it's really dirty or decrepit,
but usually put the new one in regardless. They run $8-15, and it's cheap
insurance.
I cleaned the one I couldn't get out with AZ Brakleen, the non-chlorinated
version. It doesn't leave a residue and dries quickly.
The manual (Chilton's) said to clean it with gasoline. Since I couldn't
get it off the car, I decided this probably wasn't a real good idea...
Eastern
North Shore
Begins with an "I"
Has a beach and really good clams
Eastern
North Shore
Begins with an "I"
Western.
Northern Western. Throw rocks into VT.
Let me ask you this: do you like Tar-Tar sauce? ;)
I used to live in Andover, and then (UGH!) Lawrence, and hung around a lot
in Newburyport.
with this...
Trans-X is the other goop that seems to work for the Delayed Forward
Engagement syndrome.
Dave
JessDJ
