Another Noise, 99 OBW
JohnO
I've got a noise that I think is relatively new, and maybe getting a
bit worse. Here are the symptoms:
It sounds like a high-pitched mechanical noise, from the driver's seat
it comes from the right-front. With the radio on I can't hear it, but
with it off it's there. It's gotten a bit louder over the last couple
trips I've taken.
The noise is most prominent when I accelerate at highway speeds. When
coasting at 75 mph, it's quiet, but when I press the accelerator the
noise gets louder. It seems to track the accelerator...not the speed
or rpms. With the cruise control, I can hear when it's giving more gas
based on the noise. The car runs fine, no trouble getting up to 85
mph.
In lower gears at the same rpm (around 3k) I don't hear it.
Fuel pump? The early stages of a timing belt failure? Need more info?
The *only* other symptom, which may be unrelated, is a new one. On
cool and humid mornings I see hesitation on the first jump on the
accelerator. Just once, and that's it.
-John O
If you have somebody listen closely while you reproduce the noise, can you
isolate whether the sound is coming from the speakers when the radio off?
Try tuning in a station on the AM band of your radio and see if you hear the
whine any more / less and if it corresponds to your accelerator.
When was the last time the plug wires were replaced? A faulty wire(s) may
cause a whine in the speakers and a bit of hesitation.
You don't mention the mileage, or much of anything else about the car. Any
service done to your vehicle lately?
Have you received any indicators from the check engine light, brief or
otherwise?
~Brian
otherwise?
~Brian
Good post. I was trying to figure a way it might be heat shilds buzzing.
Perhaps with worn motor mounts, under higher load situations the exhaust
system flexes enough to start some heat shield to vibrate?
Good questions, I'll try to answer them as best I can. 145,000 miles
on this beast. There is a heat shield buzz, one that took me nearly a
month to locate. Right at 1500 rpm it buzzes annoyingly. I ended up
stuffing steel wool onto the gap between the exhaust and shield in one
spot because I couldn't really see anything loose that could be
tightened or tied down. The steel wool works very well, but as
expected it rusted away. Aluminum foil is my next approach. That noise
comes from the bottom of the car, this other one seems to come from a
different place.
I haven't done anything to the car recently, other than replace the
rear brake pads last month. No CELs, no other indications of any kind.
Gas mileage is as expected.
I'm reasonably certain it's not coming from the speakers. My ears are
good at that sort of thing, but.... Would a radio noise equally come
from both channels on AM? My cell phone chirps through the radio, and
that noise is 'in the middle of the car,' From the driver's seat the
noise seems to come from the front-right side of the engine
compartment...which wouldn't be true mono. I have been fooled in the
past...in another car a loose hood spacer near the grill made the
hinge rattle, and drove me nuts for a couple years before I finally
figured it out. I have not ever replaced the plug wires, but I got the
car, a '99, four years ago. They could be old and leaky.
Thanks for the questions, guys.
-John O
Hey there John,
Check the CV joints and bearings. I have the same symptoms and I have
identified the source. Both CVs are needed. I have got a 1986 Sub GL
4wd wagon 5spd A/C. 174,000 miles.
Yet another source of whine could be the front differential - if your
high-pitched sound is like a very faint jet engine (best sound I know to
describe it!) coming through the firewall. It will continue to get louder
the longer you drive the car. Might check the gear oil in your front
differential, make sure it is within reasonable specs. Probably won't
produce vibration at the start of failure, but will toward the end. Some
tranny shops are willing to do free diagnosis of transmission troubles, and
may be able to spot if this is the case, but I would still opt for a trusted
second opinion if they say so as the repair is nightmarishly expensive.
Good that there are no malfunctions for the check engine light to report.
How about the Power light? I forgot to mention that one. The "Power"
indicator lamp on your dash that lights when you do a throttle step-down may
flash when the car is started to indicate a stored code for the
transmission, or may remain illuminated for a peculiarly long period of
time. A few months after my differential began to fail, and after I had it
diagnosed, I began receiving the trouble code for front differential from my
transmission nearly every time I started the car. Better late than never?
:p
I think you are probably right about the sound being monaural on the
speakers if the plug wires are throwing out noise, but due to obstructions,
you may not be able to perceive it as such. Should be able to rev the motor
while parked and listen to each speaker, observing obvious precautions of
course. (-;
~Brian
:p
course. (-;
~Brian
Power light...I've never seen that light before. Either I don't have
one or it's burned out like the low fuel light. ;-)
Differential, or maybe CVs, huh? OK. Does that still match up to the
fact that the noise seems to be "attached" to me pressing the gas or
letting up slightly at 75 mph? The torque causes the noise, maybe?
If so, how do I check the front diff fluid, or replace it? I read
something about those fluids here a long time ago, but the actual
details were sketchy. Maybe a tranny shop can do it for $40??? Is it
that kind of a job? CV's is going to $uck.
I'm considering selling this car in the fall...too much of this stuff
happening. I need struts all around, the tranny is just weird, and the
timing belt is past due for replacement. I can't afford all this. I
love the car, especially with our snow-belt winters, but it's too
expensive for my budget when I also include the low daily gas
mileage. :-(
-John O
Power light is on the Auto trans, can't say for the Manual trans. Carl,
don't you drive a manual, or anybody else reading this thread with a manual?
Do they still have the power light on the dash for the manual? Last Subie
manual I drove was an '89 Justy, and no, I can't recall a power light
anywhere on that one.
Differential, I would say yes, CVs, not really familiar with them whining,
just clunking, and mostly in turns and while under load (accelerating)
unless neglected for an extended period.
On the auto tranny, there is a dip-stick for the differential on the
passenger side (American) of the transmission. Unlike the transmission
dip-stick, the differential dip-stick unscrews, so don't bust your fingers
trying to just pull it out.
On the manual, again my apologies, but I really can't speak to something for
which I am ignorant, without speculation. Anybody know if the differential
and manual tranny share a common gear oil, or if there is a seperate check
for the front differential? I suppose this would be in the owner's manual
somewhere. I will try finding it later.
Never changed diff. fluid before myself. But the procedure should be simple
enough. Drain old, and refill through dip-stick hole. I can only speculate
that it would be best to drive a little, to raise the oil temperature some
and resuspend as many particulates as possible.
~Brian
~Brian
Thanks, Brian. This is an auto trans. I'll have a peek at the diff
fluid this weekend. Sounds easy enough to replace, and at 140k miles,
what the heck.
-John
Check the front license plate. If it's loose in any way, it'll sound like
what you discribe.
like what you discribe.
Good idea.
Some folks have had ABS pumps buzz. Can't see how it would manifest
itself as you describe though. And of course you may not have ABS on the
car!
Good idea.
car!
I do have ABS, but no front plate or bracket. That's similar to the
hood thing I mentioned, I'll definitely have a good peek under there
this weekend, shaking everything that could be loose.
-John
jwillin
