Thanks for the info! Probably wait till I’m off warranty.This is only a suggestion and there are providers that offer multiple solutions for multiple manufacturers.
https://www.autostopeliminator.com/products/2022-subaru-forester-autostop-eliminator
CAUTION:
Hire a Professional Technician to install this type of equipment. The bypass feature connects to the CAN (Controller Area Network) and it is NOT a toy to play with.
A Professional Technician will also test the integrity and communications of the network.
This bypass will affect your warranty - You have been warned.
I respectfully disagree about the professional technician. I installed one for a neighbor. You do need an 8mm socket wrench, you do need to be careful not to touch the eyesight cameras, and you do need to read and follow the directions. If that sounds like a problem, go with the technician.This is only a suggestion and there are providers that offer multiple solutions for multiple manufacturers.
CAUTION:
Just tried this on a 2025 outback. At first it seemed like it worked, driving around the neighborhood and stopping alongside the road.. FFWD to today, and I went out to a few stores and by the 2nd store it was stopping the engine again. To make it worse, it seems to MORE aggresively (as compared to w/o it installed) turning it off where it was a borderline rolling stop (i.e. < 0.5 secs) and it stopped repeatedly. Or a casual slow down to a stop as you wait for the person to cross in front in a parking lot and it stopped.Another test accomplished was with a trailer wiring harness installed and trailer light test adapter. The system will recognize that a trailer is being towed. A trailer light test adapter can be added to the existing trailer harness to "fool" the system..
I think this is the link you want https://www.amazon.com/Disable-Eliminator-Canceller-Compatible-Forester/dp/B09ZXZ3KXK
It depends on what model/year you have.Any way to stop the auto engine off other than hitting the switch every time you start the car?
I disagree. It's stupid simple to install. If you can plug in a lamp, you are capable of installing this little widget.This is only a suggestion and there are providers that offer multiple solutions for multiple manufacturers.
CAUTION:
LOL....I've used that acronym since I got my Legacy back in 2020! When I mention it as ASS at the dealership they don't seem to find the humor in it! ;-)Doing a little research, looks like the ASS feature is "smart enough" to not engage (i.e. stop the car) when the engine is still cold. That'd explain why the short trip around the subdivision made it seem like it was "working" to have the trailer harness w/ tester.
No bueno.
