'97 Legacy security system problem
C
cocZamudio
The factory security system in my 1997 Legacy GT failed a few days ago.
Pressing the buttons on the remote will not arm the system nor will the
keychain remote lock or unlock the doors.
I can use a key to unlock the driver's door and then use the "Lock /
Unlock" rocker switch to open all doors (the GT is a Wagon).
I've changed the battery in the remote and checked both fuse blocks for
a blown fuse.
I have not experienced any other strange electrical problems and the
vehicle has not been damaged.
Before I head off to Super Rupair, the most-excellent independent
Suburu repair shop in Boulder, Colo., does anyone have a suggestion
that I might try?
You never realize how handy something like the remote lock/unlock
feature is until you can't use it.
Cheers!
cocZamudio said:
does anyone have a suggestion that I might try?
Try another remote (if you have one).
Try re-programming your system to recognize your remote (perhaps it
"forgot" your remote?)
Cheers,
P.S. If the problem turns out to be a dead remote, relatively cheap
ones are plentiful on E-bay.
Thanks for the excellent advice!
I had forgotten that I received TWO remotes when my car was new. I dug
out the spare remote and it works fine.
You're also right about eBay: I saw new remotes for $40/pair.
BTW, good information about programming replacement Subaru alarm
remotes is online at http://www.cars101.com/subaru/keyless.html#alpine
I appreciate the help.
MSDS
