95 Legacy Outback AT Fluid Leak!
Where is it coming from?? If it's the pan then an easy cheap fix. If a main
seal the transmission comes out. ed
Tranny fluid is puring out and the mechanic wants $500 to repair! Help!
Last time this happened to me is was just one of the hoses going to the
cooler, the clamp had rusted through. Cost me 50 cents and a ruined t-
shirt to fix it.
Gee Jim, you didn't provide much to go on here. Where's the fluid
coming from? What color is it? In other words does it look burned?
Is the tranny case cracked or is the leak coming from a gasket or a
seal? What happend when you noticed the leaking fluid leaking; did
you hit something or did it just happen? ...and so on. You get the
drift.
