"90 Legacy Air Con problem
A
Alex
The compressor was replaced 4 years ago to Freon 22 , and it has
leaked it's freon , so a sealer was injected, and compressor oil was
injected 3 times in all . I keep pressure, but smell oil, and no
cooling. Could I blow out the system with an air compressor, and
refill with just the oil, and freon? It appears the system is full of
'stuff". Thanks
'stuff". Thanks
When the AC system leaks, the only solution is
having leak repaired, then go from there. You'll
probably have spent about as much in money,
aggravation and loss of use with the stop-gaps
you've done up to now...just bite the bullet and
do it right. :-/
Steve
miachapman
