jamason56
Hi friends,
I've got a noise problem that just started. I've got around 130,000 on
my car. I have a squealing or squeaking sound that seems to be coming
from the right rear of the car. The noise is intermittent and sounds
for about one second when I hear it. At first it happened when I was
lightly accelerating with the engine between 2000-2500 rpm. It sounds
like a bearing or sticking brake pad type of noise. However I have now
heard the noise while idling at a light. I just replaced the
serpentine belt, idler pulley, and tensioner (with original Subaru
parts) with no change. I have not yet heard the sound when listening
under the hood.
I have another very odd thing that's been happening for around 20,000
miles now. I occasionally feel a 'ticking' through the gas pedal and
sometimes the brake pedal while idling. I've used a screwdriver and
listened to the alternator, A/C, and power steering pump and
everything sounds OK in that area. This 'ticking' again seems to
happen between 1700 and 2200 rpm (but has occured at idle as
mentioned). For some reason I've thought about the cruise control
cable maybe moving since it's directly connected to the throttle body.
I can't figure out what else would feel so specific to the gas pedal.
BTW - lesson learned - if you pull the cruise control fuse, you will
NOT be able to move the shift lever out of park. Can you imagine
having your cruise control fuse blow, and connecting that with a shift
lever that won't move out of park?!
FYI, I'm the idiot that ran his engine during the oil change last
month <g>... (but the ticking had been occuring long before that).
It's hard to describe this type of thing, but any thoughts one what
this might be?
John
under the hood.
this might be?
John
