1990 subaru legacy
dd
Usenet Archive
i recently bought a 1990 subaru legacy (six months ago) it has 175000 miles on it. since i bought i have had to replace the timing belt and the fuel pump. thats fine. (which i did, not a mechanic)
but now my car seems to be overheating. i will be driving down the road going 60 and all of a sudden it just starts overheating. it doesn’t quite get to the redline but it gets real close. when i am a stop light it creeps up. but as soon as i take of at 35 it goes back down to about half way. but the when i get on the open road it creeps back up again.
any suggestions? i bought a thermostat for it. but i was reading elsewhere on here that someone else had the same problem. any suggestions?
thank you
Fans not working.
Engine has an air pocket.
Radiator needs replaced.
Blown head gasket.
If you run the heater and it goes from blowing hot to blowing cold whe the temperature spikes, then this is a good indication you have an ai pocket.
Is there foam in the oil? Is the coolant up to the correct amount of does it mysteriously disappear over time?
As JohninKY stated, look for those issues and hope its one of the first three but if the rad hasn't been replaced...ever... then its time. Air bubble is an easy fix, then the stat, the fan maybe more difficult to diganose...run it in the driveway and if the temp goes up and the fan doesn't kick in, you found your problem.
thank you
I have an '89 Subaru hatch and a '97 Legacy wagon. The hatch seems to be running warm because the fan is the old style with an oil-filled 'clutch' on it. I'll be trying to replace that in about 15 minutes (with a Toyota part...the only Suby clutch I can find is $165-200!!! I also have an electric fan I'll put in if the clutch doesn't fit...)
My '97 has a problem very similar to yours. No real reason as to why it overheats. Flushed the cooling system, replaced the thermostat, checked the fans (they work like they're supposed to...), in short, everything. I began suspecting a blown head gasket, but there isn't steam coming from the tailpipe at any time, not coolant leaking anywhere, no oil in the coolant or coolant in the oil (shows up as a coffee-with-cream color on the dipstick).
Brought the car to the inspection station, and explained this to the guys there. We opened the radiator cap, and he took the exhaust 'sniffer' they put up the tailpipe to test emissions and put it in the radiator. We ran the car up to 2500 RPM and watched the hydrocarbons rise on the display.
The problem here is, the leak in the headgasket is on the exhaust side and not the intake side of things. The exhaust blows out through the leak, keeping coolant from getting into the oil or out the tailpipe. The hot exhaust getting into the cooling system causes the temp to rise.
Now, my car has the 2.2 Liter engine, and everyone tells me, "Those NEVER blow headgaskets!!!"
Tell me all you want...it isn't doing *me* any good! ;)
At any rate, they have a chemical kit that can check for the presence of exhaust gasses in the coolant, or find someone with an emissions tester and try what we did.
Good luck!
My 95 legacy with the 2.2 liter had the problem of trying to overheat at certain speeds, and running fine at others. I figured out that it had to do with engine speed more than vehicle speed. You mention 60 mph. I also could not do 60 unless I was in fourth. I'd try to go 70 when I could in order to get the revs high enough to be out of the RPM range where it ran hot. I changed my oil and the problem went away. It surfaced again a few thousand miles later, and I changed the oil and it went away again. I'm not saying that old oil is the problem. But I am saying that for me it fixed the problem to change the oil. Perhaps I have the headgasket problem discussed in the last post and fresh oil is just enough to get me to the point where my coolant system can keep up. I don't know. I'd try changing the oil and see if that helps.
Good luck,
Bill
Good luck,
Bill
I think I did an oil change, but I'm not sure.
Cheap fix, though, and worth a shot!
Thanks.
Good luck,
Bill
Oh, BTW, I generally change my oil in all my cars ~3,000 miles for regular oil, and 4,500 miles for synthetic. Have all my life. My cars usually go over 250,000 miles without oil incidents...
JoeCho
