'04 Legacy Tire/Wheel ?
B
Ben King
I have an 35th aniv. '04 Legacy Wagon with stock 16" wheels. Can I
use 15" steel wheels on this car? I need to put snows on soon and I
like the price difference between 15" and 16" setups. Thanks for your
help.
If the bolt pattern matches up then yes. However, make sure you use the
same rims for all four wheels and adjust your tire size to compensate
for the reduced diameter of the wheel. Essentially you will need a
taller tire to compensate for the smaller rim so you have the same
diameter of your rim and tire together.
For example, if you are running 205/55-16 now you would have to get
205/60-15 to compensate for the smaller rim. You can check out tire
rack to double-check the conversion sizes.
Where are you from that you need to run dedicated snow tires?
Be Well,
-Kurt
miachapman
