'03 OB Parking Lights won't turn off! ???
W
Wiley
2003 Outback Wagon, automatic.
Not only do the parking/running lights not turn off when the key is turned
off and/or the steering column switch is turned off, but the fog lights
won't turn on and the headlights will not switch between high and low beam.
I've checked relays under the hood as best I can. No sign of anything
there. The only thing I can do until I can get my soobie into the shop on
Monday is to disconnect the battery. I'm thinking the steering column
switch control logic is hosed somehow, but I can't figure out why that would
affect the fog lights. Are they connected? What's going on here?
Ideas anyone?
Wiley
Oregon
Well, the mystery is solved. It seems I'm another victim of the infamous
"Parking Light" switch on the top of the steering column. I suppose I
should have dug into the owner's manual for some help, but dang...it sure
looked like an electrical problem. Now that I know the cause, I understand
how I flicked the "P" switch to "ON". I wiped down the dash with a cloth
while going through the car wash. OK, does this make me a candidate for
this year's Darwin Award?
Thanks anyway!
Wiley
Could be a short in a relay. Have to tried pulling up the emergency brake?
That should override
the DRL side of things. If they're still on then it's in the 'lights on'
portion of the circuit and not the DRL portion.
It doesn't make you a candidate for the Darwin award at all, but a
congratulations for being able to admit to yourself and the world that you
made a mistake... precious few of us seem to be able to do that anymore.
John
Pull the fuse, does light go out? Checked relay?
Find right one and pull it. Or as you said switch is stuck closed.
Tony
I absolutely disagree with you about 'bad design'! I am now on my third
Subaru and this has never been a problem with me.
In fact, the fact that you CANNOT leave your headlights on inadvertently in
a Subaru has saved me many times, and I am sure others too. The parking
light switch on the steering column is just a feature that all Subaru owners
should be/are familiar with.
John
John, the head lights have little to do with the Parking Light (hazzard) button on the steering wheel hub. Wiley and I aren't alone with that "situation" according to the dealer. I know that rocker switch is new design, it used to be a snap switch that didn't go on silently. Beside I never use the thing so never think of it.
You might not be able to leave your headlights on but you can sure leave your ignition on with radio and doors open and kill the battery! Did that while working on the Ironman here Jun 29. Had an emergency and left the car unattended while accompaning rider to hospital in the ambulance. Came back several hours later and battery was so dead I couldn't take the shifter out of Park.
Guess we all aren't as alert as you are. ;-)
Don
I guess it's different strokes for different folks. For me, I've always
appreciated the feature.
And I suppose that 'awareness' I have is going to wear away one day soon...
:cool:
John
Chris Dalton
