02 wrx wagon
I have a 02 wrx wagon that I just put a brand new iag block and rebuilt heads in. I finally finished up installing the motor and everything and it won't start it. First night crank but no ignition. Came back next morning and would crank and sputter. Everything is off the old engine which ran until it spun a crank bearing. If I spray fuel in the intake it will start run and idle. I have checked fuel pressure and it around 40psi. I'm at a loss from searching the web all day
Disregard this thread I had the fucking map sensor on backwards I saw some post about it but it only goes on one way the aftermarket intake was backwards... new problem it misfires cylinder 2 3 4 when reving above 1500 rpm
