Where is the turbo oil feed banjo bolt?
james
Does anyone have a photo showing the turbo oil feed banjo bolt in a 2002
wrx?
I just found a service bulletin saying the filter inside the bolt should be
inspected to prevent turbo damage:
http://www.boostplanet.com/subaruoilstarvation.htm
I know there's an illustration in that web site, but it is not very clear.
Also, what other parts do I need to remove to get access to this bolt?
wrx?
inspected to prevent turbo damage:http://www.boostplanet.com/subaruoilstarvation.htm
I know there's an illustration in that web site, but it is not very clear..
Looked at the link. Banjo bolt is on the backside of the passenger
side cylinder head. look for something like a .5 inch hard line. not
familiar with the newer turbos but suspect there will be some sort of
heat shield that will have to be removed. Banjo bolt should also have
a copper washer. good idea to not forget to install it and good idea
to use a new one.
Matt Walton
