Tire pressures are good, 35 - 36 PSI. I expect you are right about the sensors. I don't know if just one bad sensor will cause what I am seeing...can't tell from the manual.Are actual tire pressures okay? Perhaps just sensors. They don't last forever.
At that age, it would be wise to simply replace them all. Any tire place can either replace batteries or sensors. Don't forget the spare. Batteries have a limited lifespan, used or not.Tire pressures are good, 35 - 36 PSI. I expect you are right about the sensors. I don't know if just one bad sensor will cause what I am seeing...can't tell from the manual.
I didn't even know the sensors have batteries. Thanks for the response!At that age, it would be wise to simply replace them all. Any tire place can either replace batteries or sensors. Don't forget the spare. Batteries have a limited lifespan, used or not.
Great advice! Thanks so much!Yeah they do but most places want to sell you new sensors. The sensor only comes on after a few tire rotations, then powers down when the tire stops rotating. That's how the batteries can last along as they do.
