What does GDA mean in relation to Subaru Impreza
mike.tobin1
Hi all, I have just put a deposit down on a 2003 Impreza WRX( in the
UK).
The registration document shows it as being a "gda" variant. Does
anyone know what this means?
Is it just a way of denoting body type the same way BMW uses e36 etc
for it's 3 series.
Thanks in advance, Mike.
A lot of people throw around GC8, BC/BF, GGA, GDB, etc, but often times
people don't really know what they mean. These are chassis/engine
combinations for various model codes of Subarus. Some of these terms are
being used interchangably, when they must be uniquely identified.
When referring to a chassis alone, you use the first two characters of the
model code.
1993-2001 Impreza Chassis:
Sedan: GC
Coupe: GM
Wagon: GF
2002+ Impreza Chassis:
Sedan: GD
Wagon: GG
1991-1994 Legacy Chassis:
Sedan: BC
Wagon: BF
(Yes, the C and F indicate the same chassis as Imprezas)
1995-1999 Legacy Chassis:
Sedan: BD
Outback Wagon: BG
Wagon: BK
2000+ Legacy Chassis:
Sedan: BE
Wagon: BH
Forester Chassis:
1998-2002: SF
2003+: SG
SVX Chassis:
1992-1997: CX
The third character refers to the engine that particular chassis was
equipped with from the factory. The engine code itself implies engine size,
configuration, and other things like radiator type and crossmember used.
Due to some confusion on the VIN versus the applied model code, the table
has been revised to show Model Codes and VINs.
Applied Model Codes:
2.0L (pre-MY01 WRX): 8 (ie: GC8 is a 2.0L Impreza WRX Sedan)
2.0L (MY01+ WRX): A (ie: GGA is a 2.0L Impreza WRX Wagon)
2.0L (MY02+ WRX STi): B (ie: GDB is a 2.0L Impreza WRX STi Sedan)
2.2L (NA): C (ie: GFC is a 2.2L Impreza Wagon)
2.5L (NA-Impreza): E (ie: GME is a 2.5L Impreza Coupe)
2.5L (NA-Legacy): 6 (ie: BE6 is a 2.5L Legacy Sedan)
2.5L (XT): 9 (ie: SG9 is a 2.5L Forester XT)
2.5L (STi): F (ie: GDF is a 2.5L Impreza WRX STi Sedan)
3.0L (H6): 9 (ie: BE9 is a 3.0L Legacy Sedan)
VIN Chassis Codes:
1.8L: 2 (ie: GC2 is a 1.8L Impreza Sedan)
2.0L: 2 (ie: GD2 is a 2.0L Impreza WRX Sedan)
2.2L: 4 (ie: GF4 is a 2.2L Impreza Wagon)
2.5L (NA and XT): 6 (ie: GM6 is a 2.5L Impreza Coupe)
2.5L (STi): 7 (ie: GD7 is a 2.5L Impreza WRX STi Sedan)
3.0L (H6): 8 (ie: BH8 Is a 3.0L Legacy Wagon)
3.3L (H6): 3 (ie: CX3 is a 3.3L SVX)
Some of this information is trivial, but in some cases being specific will
ensure the correct answer to your question.
Specific model code indication required:
If you are requesting fitment of a radiator into a GFA, there are two things
to consider: GF indicates pre-MY02 Impreza chassis, while A indicates it is
a 2.0L turbo engine. For a vendor to simply reply saying that, yes, they
have a GC8 radiator ( when it is really a GC4/6 radiator) does NOT mean it
will apply to your application. It does means it will fit the GC/GF chassis,
however. Since you have a turbo engine (A), it means you probably do not
want a radiator designed for a naturally aspirated engine (6).
Specific model code indication not required:
If you ask if a STi V6 drivetrain will fit into a GC8 chassis, then of
course it will. That is the exact car the engine is in. However, if you are
asking if it will fit into a GC/GF chassis (or maybe just GF4 specifically),
then your question is less ambiguous as to what you are trying to do.
However, it is obvious to see what is being asked.
model code.
Sedan: GC
Coupe: GM
Wagon: GF
Sedan: GD
Wagon: GG
Sedan: BC
Wagon: BF
Sedan: BD
Outback Wagon: BG
Wagon: BK
Sedan: BE
Wagon: BH
Forester Chassis:
1998-2002: SF
2003+: SG
SVX Chassis:
1992-1997: CX
VIN Chassis Codes:
Thanks for the advice, that's cleared things up!
Thanks very much for the excellent post.
model code.
Sedan: GC
Coupe: GM
Wagon: GF
Sedan: GD
Wagon: GG
Sedan: BC
Wagon: BF
Sedan: BD
Outback Wagon: BG
Wagon: BK
Sedan: BE
Wagon: BH
Forester Chassis:
1998-2002: SF
2003+: SG
SVX Chassis:
1992-1997: CX
VIN Chassis Codes:
Thanks a lot for your help...
Wicked post. I have found lots of sites listing the various codes but most
stop at MY00. This is one of the clearer ones :
http://www.importcarparts.co.uk/tech/model_codes.htm
Matt
Dove788
