Timing Belt Replacement Work
Jack
It is time to have the timing belt replaced on my Y2K OB. I have
heard on the Subies that when you do the timing belt you should also
do the water pump, front seal and cam seals. Is this correct? Is
there anything else I should consider?
thanks
Jack
All good practice. Add oil pump seals: front seal and o-rings on back of
pump.
pump.
This may seem like a lot of over-kill. But think about it this way, if
you keep the car for 200,000 miles you are only having to do this 4
times. And you saving the need of having to track down any oil leaks.
The peace of mind is worth the expense.
BlueSTi
"Scary-Fast"
Rick said:
pump.
I'd also add belt tensioner, fan belts, plugs and
new coolant.
The belt change interval is 105,000 miles. Do water pump, all seals
including oil pump gasket and o-ring. Inspect belt tensioner carefully and
change if at all questionable. ed
SALTO_JORGE
