Temperature spikes
Howdy. First post, but I promise, I searched. I found one thread from 2007 that mentioned an identical problem, but no solution posted.
Last October my mother bought a 2000 Outback (2.5, AT). The previous owner had paperwork for a timing belt, and said the head gaskets were done but had no paperwork. My brother took it to a shop for an inspection and they say it's obvious to them that it was done at some point within the last couple years, along with a new radiator. So we're driving the car, and it never heats up. The CEL is on, so I get it scanned, and there's a code for a bad thermostat. I've never heard of a code for a thermostat, but whatever. My mother doesn't drive much, so we went through the winter with what I presumed was a thermostat stuck open. It's a PNW winter, so it's not that cold.
A couple weeks ago I got a new 170 degree thermostat from AutoZone and put it in. As it turns out, the old thermostat was busted up so there was just a metal frame in there, not the spring and closure flap, so basically no thermostat. The coolant looked good when I drained it, but I put new in anyway. I ran the car a bit, the gauge was right in the middle at the 9 o'clock position, let it cool, topped off the system and the reservoir, and everything seemed to be fine. Even the CEL went off as soon as I put the thermostat in. However, the car has a weird overheating problem now. I can run it on the highway no problem, or in town no problem, but if I'm driving at highway speeds, then get off an exit and my speed drops to city traffic speeds, the temperature gauge spikes almost to the red. It will cool down after a couple minutes, but it makes me nervous and certainly doesn't seem normal.
I've been driving the car for 3 weeks, sometimes with the A/C on, and the temperature only spikes in that one specific situation. It doesn't lose any coolant, the heat works fine, both radiator fans work, and the radiator doesn't have any cold spots. I'm at a total loss. Only thing I can figure is maybe a sensor that's not turning the fans on at the proper temperature, but that's a total guess on my part.
Any suggestions would be appreciated.
Look at the "foam panels / inserts" that cover the radiator side ends with the top / bottom of the radiator.
The foam inserts force airflow through the radiator and condenser assembly.
A damaged thermostat with missing pieces looks like something was hidden.
Make sure all air is bled from the cooling system and that the water pump is keeping up with coolant flow.
A decade box or variable resistor can test or fool the engine controller to enable the fans, control the temperature gauge and be monitored with a scan tool. if unsure, purchase an OEM temperature sensor.
Make sure the transmission cooler is operating and transmission oil is full.
Head gaskets and timing belt is suspect with no invoices or proof.
Pressure test the cooling system while cold.
Make sure there is no debris in the radiator or cooling passages.
I'm having the same issues. My wife cooked the 2.5 on our 2011 outback(split radiator & didn't pull over and shutdown in time), so we put a motor in it (55K miles on it). Many coolant parts were changed radiator, hoses, themo, radiator cap, subaru coolant.
When we drive on the highway (80mph)and get off the exit the(stupid) idiot light comes on(why not a gauge instead of mpg gauge in that location). Pull over shut it down, wait and drive away, no problem.
The next time we went on a long trip I bought a scanner to monitor temps (hi-way...180 - 194 degrees). Got of the exit and it shot up to 240+ degrees, fans on, some coolant came out of the overflow tank. Let it cool down, drive away, no problems....
Any ideas......my $4500 car has now cost over $10K, but its done (full brakes, timing belt, tires, etc). As a side note the trans was replace by the dealer 30k miles ago by the previous owner. So the motor has 55K miles & the trans has 30K miles....I hope to recoup some $$ by putting a 100K miles on our "new to us" subaru
No one.....where are the Subaru savants here?
Every other car forum has them....even the Mazda 3(my son's car)
Dove788
