Tail Light Bulb Assembly
.._..
I have a bulb out on the corner tail light (one of the red running light
ones) on a Subaru Outback 2001.
It appears the little plastic door is the access inside rear compartment is
the access.
Inside, is a wire disconnect and a thin bolt and nut.
I assume that the wire needs to be disconnected, and the nut removed, once
that done the whole plastic assembly comes off where there is access to the
bulb?
If not, how should the bulb be changed?
Shopscape50
