T70 Torx socket
For torx bolts, this is the best way to get the right one.
#1, get some silly putty or play-doh (or other clay-like material)
#2, push a blob of it into the torx bolt to make an impression of the bolt
#3, go to an auto parts or tool store & buy the torx bit that is the same
size as your impression & fits your standard 3/8" ratchet.
#4, start wrenching!
Done!
-T
Done!
However - if it's a T70 (as I hear the front diff plug on 2004
automatics is) then I haven't seen a tool shop, hardware store,
or auto parts store that carries this bit. I've only seen two
US-based internet tool stores that have this part, and one has
it in a 100+ piece set that I don't need. The others I've seen
are based in England or New Zealand.
I've tried Sears, Home Depot, parts stores, tool stores, and
tracked down a Snap-On Tool truck. They don't even have a T70
socket in their catalog. I'm thinking it's only going to be a
matter a time before I can find this part in my local Sears for
$10, but I can't find it now.
y_p_w said:
OK-
Before I go out and get the following part, can anyone verify that a
T70 Torx socket fits the Torx head drain bolt on a 2004 WRX manual
transmission? It's been verified here that the T70 works for the
front diff plug on 2004 front diffs (automatic tranny
They are so cheap, buy a set of all the sizes for goodness sakes
The T70 is hard to find - I picked up a set of torx stuff on eBay a while
back which goes through T70 for internal and E20 for external torx - they
are hard to find individually - if you search on google, there are a bunch
of vendors which have them, usually as part of a set - I found one for $30
or so while looking around - lots of UK vendors - maybe one of them will
ship?
ship?
The one I found was $21.95, and shipping started at $6.95. I'm thinking
maybe I can find other tools I need/want and have them shipped in the
same order.
OK-
front diff plug on 2004 front diffs (automatic tranny).
<http://www.toolsource.com/ost1/prod...900&mscssid=SEFW19LXC0TH2GDU00J74FSANRGQ4TUA>
The manufacturer (Stahlwille) seems to be German.
http://www.scoobymods.com/forums/sh...eadid=9&highlight=changing+transmission+fluid
i don't see any torx heads on my car with the 5mt??
ken
This seems to be something Subaru sprung on unsuspecting owners of
2004 model year cars. I hear it's for the front diff plug on
automatics, and I know it's on the manual tranny drain bolt for my
2004 WRX. I posted this picture in another thread:
<http://home.earthlink.net/~calvbfan/sitebuildercontent/sitebuilderpictures/transmission_plug.jpg>
I just got a response from Lisle Corp about whether they had one
or were planning on making one:
"We were not aware that T70 torx fasteners were being used. At this
time
we have no plans to make a T70 torx bit socket. Thanks you for
contacting Lisle Corporation.
Sincerely,
Lisle Corporation"
I dug around, and it seems that some British auto makers have used
the T70. T80, T90, and T100 Torx bits are also available in England.
I think I'll just get that one I found - and maybe a clicker-type
torque wrench on top of that to justify the shipping costs.
y_p_w writes :
You won't need the torque wrench, nobody know the value
for the drain plug.
Paul said:
y_p_w writes :
for the drain plug.
I thought I saw a value on a thread in Scoobymods for the 2002.
Should be the same value I'd think.
However - I want a clicker torque wrench anyways. :)
Ok - it said 32.5 ft-lbs or 44 N-m. I really don't think they
changed anything except the bolt head from a 6-pt to Torx.
wow, that sucks.
if the threads/dimentions are the same then go to the dealer and buy a
replacement with a "normal" head.
see also:
http://forums.nasioc.com/forums/showthread.php?s=&threadid=505576&highlight=transmission+drain+bolt
hope it works out for you.
Thanks. I'll check it out later.
Still - I'd have to find someone with a T70 socket (a dealer service
dept?). I was in to get an armrest extension installed this morning,
and noticed my dealer charged a whopping $130 for transmission
service (although it could be the auto). A new 6-pt magnetic drain
bolt is probably $10-20. I think in the long run, it might just be
a better idea to get the Torx socket (and not lose it).
I've actually got 4 quarts of Redline 75W90NS sitting in my garage.
I figure the first oil change at 3K miles is as good a time as
any to switch over.
Part no. is 32103AA012 and it lists for $10.57
I have no idea if the threads are the same or not, though. I would consider
asking the dealer about the t70 bit, too - it's probably down as a subaru
special tool or something like that - maybe it's not too expensive...
Were you able to get the socket? Did it work out okay?
Not yet. I was thinking of doing it at 3K miles, and I'm
about halfway there. Maybe I'll order it this week.
Similar Threads
Followup - T70 Torx socket 0
Torx T70 Availability 6
Donnyboy
