Subwoofer 2002 Outback LL Bean
A
AO
I just bought an 2002 Outback LL Bean and would like to install a sub
in it. I have 4 12" subs from other cars laying around but they
almost look to big to be able to fit any place in the vehicle. Is it
possible to use these some place in the car without consuming the
space in the rear? Maybe in a side panel or in with the spare tire?
If the 12 is to big, what size have people used? Also, is there any
documentation out there on how to tear apart the dash to replace the
cd/tape deck? Thanks in advance for the help.
If you're content to drive around without a spare, You could get at
least one of those in that well--perhaps 2. You can measure the
volume using packing peanuts and port accordingly. A buddy did
something similar in an Integra long ago to good effect.
The side panels are way too small for a 12, best I can tell.
An alternative would be a free standing box. That's worked well for me
in the past and has the benefit of being removeable when you need all
your cargo room.
Best Regards,
Thanks a lot for the response.
Do you think there is any way of being able to leave the spare in and
using a 10" sub or something for example? It would be my luck I put
all this fun stuff in there to have my wife drive it and get a flat.
ha... Have you ever heard of anyone putting a sub in the side panels?
What size sub are you running currently in your free standing box? I
am an amature at this but if i put an 8-10" in there would that sound
OK do you think?
Do you know of any guides online on how to take out the factory deck
by chance?
Thanks again.
OK do you think?
by chance?
Thanks again.
I think adding any sort of driver that's larger would help matters.
I've gotten old and don't have a sub in my Outback, but I ran a single
Fosgate Punch 12 in a freestanding bandpass box in my 626. If I had
it to do again, I wouldn't do a bandpass box--thing sounded kinda
crappy. i'd go with a direct radiating box and feed it plenty of
power (not that you need much in a space as small as a car).
I've considered the underseat subs that Subuaru sells... but never got
much farther than that. The audio quality of the stock sytem is okay,
but I do miss having some real bass. But I haven't missed it enough
to pony up dollars given other priorities. :)
I mounted my 10" sub in the right rear compartment after removing the not so
useful box. The whole box came out with no cutting then I fashioned a cloth
cover over the hole. I put my amps in the tray over the spare.
Thanks for the info. You don't have any pictures by chance do you?
Did you make a custom box and such also for the sub? Thanks again.
Similar Threads
miachapman
