Speaker replacement in Legacy GT
W
WOOFER
Trying to purchace and install replacement (upgrade) speakers in the rear
deck of a '97 Subaru Legacy GT sedan. All web sites list replacement size
as 6.5" but what I removed was more like 6.25" and the 6.5" replacements are
definately oversized. Anyone know what fits and who sells them? I'd like
to avoid resizing the existing holes. Thanks to one and all!!
Hyperdog
Hi Hyperdog!
Large speakers into the doors can be sorta challenging, but you
_should_ be able to fit pretty much whatever you want into the rear
deck. I have installed 6 inch Infinity Kappas in these cars w/o
problem, with the tweeters surface mounted to the deck panel.
You will have to make new screw holes as the Subaru speakers use a
three screw pattern. This is the most troublesome part of the job. A
right angle drill motor simplifies this, but you can make at least
three of the holes with a conventional cordless drill. Do without the
fourth if you must.
My advice:
Pull the rear seat/seat back to get good access to the rear deck and
deck panel.
Cut out the perforated areas of the deck panel and use the grille
supplied with the aftermarket speaker. Mount the speaker thru the
panel, rather than below it. Drill pilot holes before dropping the
speakers in place to minimize the chance of putting a driver bit thru
the speaker cone. Also, watch that you don't put a drill bit or screw
thru any wiring beneath the deck, and aim to miss the torsion bar
springs for the trunk lid as well. Having a screw touching one of the
springs will result in an annoying buzz/rattle.
For best results, get a pair of the foam speaker baffles (from
Crutchfield or where ever), and use them either below the deck panel
(best appearance) or above (easiest installation). This is especially
important if you plan on placing a subwoofer in the trunk.
IMO, decent speakers are the best upgrade to the sound system in these
cars, and should be installed before spending $$$ for a high
performance head unit. A modest sub in the trunk adds a lot of
solidity to the sound as well. For cost, performance and ease of
installation, it's hard to beat the Infinity Basslink; $100-$150 on
ebay.
Feel free to contact me directly if you'd like more nfo on this.
Hyperdog
Try Crutchfield.com
http://www.crutchfield.com/S-549CUZJ4Jw3/cgi-bin/SuperProdGroup.asp?g=399
shows quite an assortment of speakers both in 6.5 and 6.75 inch
varieties. I didn't bother sorting out the front versus back items as
I'll leave that to you.
From personal experience; if Crutchfield says it will fit; they are
right. I've had *one* variation; it was on a "first run" Ford Ranger
pickup that was weird in many other ways as well. Even then, using the
adapter ring under (instead of over) the factory location worked
"Thinner" overall larger speakers can fit smaller holes with proper
adapter rings. Sometimes the adapter rings go behind (or in your case
under) the existing mounting hole. It was common in the 60's and 70's to
see adapter rings to put 6x9 speakers under the rear deck where 5x7's
(or smaller) existed.
As an aside: How did you measure the speaker diameter? Even the speaker
manufacturers can't agree on the sizes of newer speakers; let alone what
the screw patterns are.
You have it fairly easy, at least you have existing holes. Back in the
old days before stereo; cars had either none or one speaker mounting
hole in the center. Putting in stereo speakers meant spending some
extensive quality time upside down in the truck with a metal-cutting
saw. There is no way to shield your face completely from those chips.
Staff online
mcselee
