Someone gave me a hint of a leak around the water pump, 1989 1.8
  • Start date
H
A few months ago when I was tracing an 'overheating' problem (I think the
radiator was the culprit) someone mentioned a leak that develops somewhere
around the water pump.
I appear to be getting some leaking from this area.
However, when I was taking things apart to get to the oil pump, I may have
loosened something I shouldn't. I'll have a look tomorrow or Tuesday to
see if this is the case.
<sigh>...I hope I don't have to take the whole damn thing apart again...
That large metal tube topside of the pump is just a press fit with an
O-ring. Often times it will develop a leak there. New O-ring and
that problem is solved.
O-ring. Often times it will develop a leak there. New O-ring and that
problem is solved.
But...that's what you told me about the oil pump!! ;)
I don'y knkow if the gasket stopped the clacking, because it doesn't do
it in warmer weather...
Thanks for the response, though! I'll have a look this afternoon.
