I would have to recommend Compustar, Avital or Crimestopper in regards to
good remote starters. Bulldog is JUNK, Autocommand is Ok, Viper/DEI stuff
is good, Astrostart is very good but harder to install. I have been
installing remote starters for over 10 years and this is just my opinion of
what I like, others may disagree with me, that's fine. Just make sure you
get a unit that is designed for manual transmission, otherwise there will be
liability issues should it accidentally start in gear.
Here is a list of which wires may need to be tapped for the starter to work,
as always test all wires before making final connections, having said that,
I remove myself from all liability for improper installation of this device.
Function
Vehicle Color Location
Start Wire: (Power while cranking ONLY)
White/Black Ignition Switch Harness
Ignition #1: (Power while cranking & when in ON position)
Yellow Ignition Switch Harness
Ignition #2: (Same as Ignition #1)
Green/Orange Igntion Switch Harness
Accessory: (Power when in on position, NOT while cranking) Green
Brake Wire
+12 Volts when brake pedal depressed)
White/Black Switch Above Brake Pedal
Tach Signal: (AC Pulsed output when motor is running)
Blue 3 Pin Plug at Ignition Coil
Parking Lights: (+12 Volts when parking lights are on)
Purple 10 Pin White Conn in Drivers
Kick Panel
Constant +12 Volts:
White Ignition Switch Harness
OEM Horn (-12 Volts when horn depressed)
Yellow Blue 28 Pin Conn. Abover
Steering Column
Power Lock (-12 Volt Signal when Lock button depressed)
Red/White In 10 pin Connector in drivers
kick panel
Power Unlock (-12 Volt Signal when Unlock button depressed)
Yellow/Red In 10 pin Connector in drivers
kick panel
I am not sure what color the clutch bypass wires are, but they will be on a
switch above the clutch pedal. You will probably also have to have the
parking brake wire hooked up as a bypass, again I am not sure of the color,
but there should be a single wire coming from the parking brake handle that
while go from an "open" condition to a -12 Volt (grounded) condition when
the parking brake has been applied. Another thing to consider is if the
vehicle has a factory alarm system, in which case the -12volt "OEM Alarm
Disarm" output from the remote starter can be used to trigger the UNLOCK
wire thereby temporarily bypassing the alarm and allowing the vehicle to
remote start, the remote starter will then automatically relock the doors
(assuming you have that function programmed to do so, read your instruction
manual for further information).
Feel free to contact me in this NG if you have any questions regarding the
installation or any other remote start applications, I will be happy to try
and assist
