Rear wiper motor Legacy wanted
Had what I thouight was a bad wiper motor on a 98 Legacy GT wagon.
Mootor was fine but shaft that wiper attached to had seized into the
alloy housing that the motor and wiper sfat attach to.
Removed assembley taped out shaft with a wood block to not damage
thread. Once apart drilled out housing to increase clearance and
reassembled. All is working fine now two years later.
May want to check for corrosion bonding the steel shaft to the aluminum
housing before you buy a motor
Similar Threads
Rear window wiper motor burned out -- again 15
rear windshield wiper fuse 2
Rear wiper motor 13
Weak rear wiper 5
rear wiper motor? 6
Rear wiper motor 1
Rear Wiper Arm Removal 1
rear wiper motor 1
Donnyboy
