radio wiring subaru SVX
C
cycleman50
I had my car in the shop. They took out the driver seat to repair. Now my
radio antenna will not go up and the light that shows what station you are
on does not show up at night. The radio works, but without the antenna up
it is poor reception. Anyone got ideas where to look to see if the
connections were all plugged back in??? I see on the antenna motor there
is a black/green wire, a black and a white - but have no idea where the
harness goes when it gets to the front of the car.
The power antenna harness always starts at the radio. Always part of the
radio harness. Almost 100% the shop cut the antenna power wires or just
disconnected it and forgot to reconnect it. If the antenna is located on
the driver side you can expect the harness to run under the driver's seat.
Agreed - it is under the carpet under the seat.
Also you should check out www.subaru-svx.net
If you don't find the problem and post the question in the technical Q&A
forum and you'll get experienced help there.
I would take it back but it was a school project for auto shop, and school
is now out.
I looked under seat and can only see two sets of wires that come out of
carpet and hook into recepticals on seat.
I looked on side of door by fuse panel and everything seems to be hooked
in correctly.
Can anyone help me by being more specific as to where to look?
