Please help with seatbelt problems (2nd cry for aid)
C
Computer User
Does anyone here have any advice about fixing the driver's automatic
seatbelt on a '93 Legacy? It seems like it wants to work (sometimes) but all
it does is jump a little bit when the door is opened.
Could any suggestions be offered as to where to begin to trouble-shoot?
Is there any place on the web that has any diagrams of how they work or how
to get into them?
Thanks in advance for any help!
It is safety device. Don't mess with it. Dealer is obliged to fix it.
Tony
Hi C.U.!
I've replaced this twice on our '93 Legacy, and it's broken again. It
is a sealed cable operated assembly, and there isn't much you can do
short of replacement, which is a mild pain in the butt, but doable. Be
warned that it's a pricey little PoS; $125 at the scrap yard (if you
can even find a good one), probably closer to $300 from the
dealership!
What I have done _this_ time around (probably won't help you much) is
when we noticed that it was starting to act up _again_, I kept cycling
it til I got it to go all the way to the back position and then
clipped the leads to the motor. Now at least you can manually work the
shoulder belt.
The motor/cable spool is located behind a trim piece in the pillar
between front and back doors. I suppose it's possible that you could
work the cable into the back position from there, but as it's the
cable that seems to be the problem child, I wouldn't be too hopeful.
Sorry to bear bad news, but this is a crummy implementation of a
stupid governmental mandate ("Passive Restraint System" Thanx, DOT)
that has since been replaced by the ubiquitous air bag.
Hi Tony!
Even on an 11 year old car with (in our case) 280K miles on it? I'd be
real surprised if that's the case, but if so I'd just _love_ to dump
it in the dealerships/SOAs lap. Why do you think the dealer is obliged
to fix (w/o charging $500+ to perform the service)? Part of the same
"Passive Restraint" mandate? Inquiring minds would love to know!!!
How does it wrap when you put it on. Compare it to the passenger side. I found
mine was twisted and didn't pull back properly when I opend the door. Kept
bumping the lock assy into the plastic on the door jamb area. After finagling
with the strap (wasn't easy but I did it) I turned the strap over and it wraps
around me flat, NO TWISTS.. Now it returns very nicely and I have heard a bang
or smash in the door as I close it.
Phil
