OEM Cat converter for '02 Impreza?
R
runcyclexcski
My '02 Impreza Outback got 121,000 miles, and my local subaru dealer
has got a Cat converter check engine code reading.t. They quoted me
$850 to replace the Cat ($650 part + $200 labor).
All I need is to pass the California smogs. I am not driving the car
much anymore anyway (gas prices), just keep it in the driveway for an
occasional camping trip (still cheaper than renting... provided no
major repair costs) so giving out $800 just to register the thing just
does not sound right.
Goggling produced a $150 (???) "Catco" converter. Does anyone have
experience with this beast? Can I bolt it on myself to keep the
smoggers happy?
Also, I am not sure if the sensor in the car gives a yes/no kind of
answer, or actually produces a real number. Meaning that if I knew
that the reading was on the borderline, can I make the car barely pass
somehow (heard some urban legends on driving on a highway before the
test).
smoggers happy?
test).
An aftermarket cat shouldn't be a problem, but its not as easy as
bolting it on. You'll need to cut the old one out and weld the new one it.
And the sensor on the car is just yes/no.
I would clear the code and then have the car smogged before dropping $80
on a repair that may not be needed. If the car fails the test, now yo
know for sure you need a new converter. Passes then the original proble
was just an O2 sensor failure.
I would clear the code and then have the car smogged before dropping $800
on a repair that may not be needed. If the car fails the test, now you
know for sure you need a new converter. Passes then the original problem
Thanks! It's interesting that there is no way of telling is it's the
detector problem or the cat problem.
I think the sensors can be scoped to see if the switching is fast enough
and in the proper range. DO NOT try an ohmmeter reading. Some ohmemeters
will burn out sensors. Thsi may be less of a concern with wideband
sensors - I dunno. I wouldn't risk that.
You can try installing a spacer on your rear o2 sensor. I have a catless
exhaust on my 03 WRX. The spacer pulls the o2 sensor out of the direct flow
of the exhaust , no CEL and gets threw emissions. Costs about $2. You get 2
spark plug spacers available at any autoparts store. I can dig up the part
number if you need it. You will need to drill out the opening some on the
spacers too.
spacers too.
I can see how that can clear the check engine light but how would that
affect the smog check readings?
A couple of thoughts after "interesting" experiences getting past
California smog tests:
Cats do go bad, but it's far more likely you've got an O2 sensor
failure. Not sure how many sensors you have, but it sounds like you have
one in the exhaust stream of the cat. My smog guy tells me this one
rarely goes out (if it's throwing a code, it's obviously working), but
can tell you one of two things:
First is the cat's dead. Think big bucks as you've heard. He says
"emissions wise" the cheap replacements do as well as OEM. HOWEVER, I've
seen nothing but grief down the road w/ OEMs, both on my cars and
others. It starts w/ the installation problems: they usually don't just
bolt in like OEM. From there you could have heating problems--the guys
I've seen put 'em in weren't always the brightest when it came to
figuring out WHY the factory spent all that money for heat shielding! I
was lucky--my carpet only got "warm." An acquaintance wasn't quite so
lucky--he burnt the carpet in his truck pretty badly. So... if you don't
care about driving the car much in the future, go "cheap" but if you
want to return the car to "constant" service, suck it up and buy OEM.
Doing so saved me money in the long run.
The other thing a cat code could mean is the upstream O2 sensor(s) is a
goner. The mixture going to the cat is too rich for it to handle
properly. Nothing wrong w/ the cat itself, it's just overloaded
(especially problematic as the systems age.) Not such big bucks to fix.
My current smog guy says the upstream O2 sensors are generally good for
about 60k miles (though some last longer, none I've had made it past
100k), and cats for about 150k. So you're due for O2 sensors "again"
according to him, but still have another 30k on your cat. Generally!
Were this my car, I'd start by replacing O2 sensors, resetting all
codes, and starting over.
Now, for "urban legend" and such: the entire emissions system HAS to be
up to operating temps to work right. Again, as the car ages, this
becomes more important. One of my smog guys always told me to drive the
car 5-10 miles to get things hot. Another always blocked the throttle
for a full minute to two minutes to make sure the cat in particular was
"hot." My current guy says both approaches should be combined.
He also suggests any time you're "not quite sure" to have a "pre-test"
done. This gives all the readings w/o upsetting the DMV computer w/ a
"failure" reading that stays on the vehicle record (ever do a CarFax
inquiry and see the "failures" on some cars?) He charges me half the
regular price of a test for the pre-test, and applies the charge to the
real test if I'm ok. In other words, if I fail, I pay half price, go fix
whatever it takes, then come back and try again. If it passes the
pre-test, he'll run it again "for real" and only charge me the one full
fee.
You might ask your guy about doing this since you've already had
problems.
Good luck!
Well it wouldnt. They dont do those here, depends on the year car i think.
They just hook mine up and look for codes and do a gas cap pressure test.
smoggers happy?
test).
Hey there,
I had a similar problem with my 2001 Impreza Outback and I subscribed
to ALLDATAdiy.com and it has been very useful. I am handy and like to
do things myself and this subscription gives me diagnosis, repair,
TBSs, recalls and labor times.
Check it out - I copied the link below for you.
http://traffic.alldatadiy.com/cgi-bin/redir?pd_link=i1-a44690-o4010-c66365
Andy Deil
smoggers happy?
test).
Hi all,
I bugged you guys ~2 months ago about a cat converter error code on a
'02 Impreza, and I got some very good suggestions from you.
The problem was an check engine light on (code P0420 - "cat converter
below thershold efficiency"), and my dealer was trying to convince me
to spend $800 on a new CAT. I can't pass the CA smog test with the
test engine light on.
Well, my registration is due in 2 weeks and I just took the car for a
smog test (the dealer protested, saying why bother - well, since the
retests are free, why not).
It passed the smog test ***easily***. At idle the numbers were:
14.6% CO2, 0.1% O2, 17 ppm HC, 0.03% CO, not anywhere close to the max
allowed numbers.
So I runs back to the dealer and ask them just to replace the front O2
sensor. But they *insist* on replacing the cat converter, saying that
if the system says it fails, it fails.
So the question is - how can the cat converter be faulty if the
emissions are fine? Or do the emission people and the cat converter
sensor measure different things?
I can insist on replacing just the O2 sensor ($250 as opposed to $800)
though, but at this point I don't know if I can trust them at all -
unless I misunderstand something.
fee.
problems.
Good luck!
I got a second opinion from another mechanic and he suggested
replacing the upstream sensor. But how can an upstream sensor throw an
error about a downstream component (i.e. cat)? Weird. Funny how you
can spend $250 to replace a sensor, and still don't know for sure if
it's going to fix the check engine light on.
Hi all,
allowed numbers.
There is no direct way for the OBDII to measure cat performance other
than comparing the upstream and downstream sensor values with ideal
numbers in memory.(basically) So, for most cars, it would be like trying
to measure one old component using 2 other old components. But a GOOD
shop should be able to perform tests on the sensors that would show slow
switching or a failed heater circuit, etc. They should also be able to
do a tailpipe emissions test. Basically, your dealer is either corrupt
or incompetent (hard to see a 3rd option here).
This not say its impossible to have more than one bad component. Or,
indeed, replace one now, and need a second component replaced in a few
days/weeks w'ever.
try reading a couple of articles here;
http://www.troublecodes.net/articles/
OBDII..simply explained
Cat. Eff. Failures
days/weeks w'ever.
try reading a couple of articles here;http://www.troublecodes.net/articles/
Cat. Eff. Failures
Carl - so, would a good emission test argue against a bad converter?
My other mechanic says that the upstream sensor fails statistically
more frequently because it experiences more stress (the sensor
generates voltage, right). I kind of buy that.
Since your original post, my 01 has thrown this very same code. And
supposedly, I have a brand new aftermarket cat that's under a year
old.
FWIW, I reset the code with the scanner I own ($100 at Wal Mart made
by Innova.) The code didn't come back for another month or so,
which gave me 3 weeks of no-CEL driving during which the counters were
also clear (i.e. would pass emissions). I think it took about a week
of driving to build up enough engine time to reset/pass the rest of
the stuff that makes for a happy emissions odbii check. It isn't
considered "clean" right after you reset everything.
Anyway, if you are blowing clean emissions, and it does just look like
a sensor issue, you can have a buddy with a code scanner reset your
code, wait a week and have them recheck to make sure all the
counters/such have gotten to their happy place, then immediately go in
and have those emission checked, and you may make it another year.
Just one option anyway.
I have read MANY reports of upstream sensors failing WAY before the
downstream unit. There are probably 2-3 reasons for this in various
combination(heat, more corrosive gasses,etc.). Not impossible to have a
bad converter or bad downstream converter - just difficult for the
upstream sensor to last much over 80,000 miles or so. Could some last to
130K? probably. Some also fail at 60K or less. Especially if they have
been exposed to coolant from a leaking HG or other stresses. And it is
often a 'slow' failure. Sometimes the code can be cleared and may not
return for weeks.
There probably are some rare mechanical ways a Cat converter could be
partially clogged but still pass an emissions test - dunno - but the car
would probably have driveability isues at high speeds or under load.
Chris Dalton
