Dennis Maher
Has anyone used a K&N Air Filter on their Outbacks or Forresters. If so, did
it help performance or was it difficult to install.
TG said:How long was it in? A little more time might have cured everything. Changes
in the intake need time on modern OBDII cars. TG
so,
Date: 4/6/2004 3:43 PM Eastern Daylight Time
Message-id: <zLDcc.4400$mn3.783@clgrps13>
I installed it on my 2002 Outback STW. Really easy do it job.
One problem, though. After installing it I noticed engine
knock/detonation (ping). Went to my service shop and decided to take it
out in order to reduce it.
Yes, car was a little bit more peppy, but it was taking more gas as well.
Voja
Voja said:I installed it at 24K km. Just after 50K km I decided to get rid of it
after long fight with my *ex*service shop re. engine ping.
I'm not all that convinced they keep out dust as well as an oiled
paper filter (like OEM Subaru). I once bought a drop-in K&N and a
recharging kit. You can see through the mesh. The oil allegedly
attracts dust by static attraction. They claim small cotton fibers
are in the mesh holes, and that you have to really be careful
cleaning and drying the filter when recharging it. The main thing
I noticed about the K&N was that the air box did get louder. Even
my dad could tell.
I've heard of people using K&N filters, who stopped after oil analysis
showed excessive oil contamination. I've also saw an auto magazine
test of a K&N cone filter. It definitely improved top end power,
but it actually decreased power around 2K RPM.
Chris said:That's about what my experience is with mine in my truck. Much louder
intake, better top end, same or worse low end. Maybe more dirt int he
oil but I never had it analyzed, there was never any dirt in the
downstream side of the air intake. There were server trips on long
dusty trails for hours behind another 4x4 where paper filters would have
been clogging in no time, like the AC vents and even my CD player were.
As it was I had to clean the K&N a couple of times in the field. On
regular roads I don't think I would go K&N again, when I finally do get
my Subaru I'll probably stick with aftermarket paper filters.
GRL said:I've said it before, but here it goes again.
Before you install that K&N, ask yourself which manufacturer specifies K&N
filters for their cars from the factory? Recall that with many
high-performance brands, Porsche, BMW M's, Vette's, etc., price is really no
object as what they are after is power; so if a $50 air filter us power even
a little with no deleterious effect, they'd specify it for competitive
reasons.
The answer is...none.
Further, every now and then Car & Driver tests these things as a
after-market part add-on for one of their test cars. I've been reading C&D
since the 60's and they have NEVER found a performance benefit over a oem
filter.
On the other hand, if you are just after more intake noise or the right to
have a cool K&N sticker on your car and don't worry about silica and other
crap getting in your engine, go for it.
End of discussion, no?
the last time you bought a part at a dealership that didn't have the car
manufacturers name on it?
I don't think _any_ manufacturer installs oiled-gauze air filters.
Subaru oem and Purolator (autoparts) are oil impregnated which is different
than just spraying oil on the filter media like K&M. ed.
Chris Phillipo said:Honda has oil/foam filters for just about everything.
The Honda filters are washable. Just about every manufacturer has a
washable foam filter for high dust environments. I've been on trails
that clogged a paper filter to the point of causing the engine to
sputter in under 3 hours. Of course the guy in the lead didn't have any
problems![]()
